Burnt Receptacle...
The damage was to severe to tell anything, all I ended up with was a bunch of bare copper conductors, could not tell a EGC from a ungrounded conductor. let alone tell if the screws were actually fully tightened.
OK, gotcha. Did you happen to look at any of the other boxes or was there any open wiring that you could inspect for clues to amateur hacking?
It was 6:30 at night, didnt really look around too much, just tore out the burnt stuff, removed the staples holding the NM's to the stud, stripped the NM back to a good spot and installed a old work plastic box, turned the circuit back on.
so far all evidence posted is from screw terminated devices. Show me one of back-stabbed devices.
Your wish is my command.
What do think the cause was? A plumbers torch?
see above...I don't have alot of experience with finding these problems, and I haven't ever seen a burned up outlet so I have nothing to go off of. So I don't know if there are other possibilities other than arcing due to a poor connection.
