polls wrong roger!![]()
Doesn't matter what any individual thinks, the numbers are what they are. If the poll was not meant to play a part in this it wouldn't/shouldn't have been started
Roger
I have, 60% of you are WRONGLook at the poll Jim.
Roger
Majority does not make you right, it is just score of the answers.
If 100% of us agreed that #12 thhn could carry 50 amps would that over rule NEC ??
Wouldn't happen. The polll says what it says. You're wrong
Again, I'll assert that something is wrong with the text of 358.30. The only way it can be "(A)" AND "(B)" is if the EMT is secured as required by "(A)" and is supported by passing through framing members as required by "(B)". "(B)" doesn't say any other type of support is "permitted". Does that seem reasonable? Is EMT only allowed to be used when supported by passing through framing members (ignoring the exception in "(C)")?
Once again i will point out that doing A does not always result in supporting.
Excellent point. If you have to do both, then you can only use EMT when running through framing members. We all know that is not true, therefore, it cannot be both A&B are required.
. . . I will simply chock it up to not being able to admit you have been wrong in this thread
? Person 1 says, ?The sky is blue.?
? Person 2 says, ?The grass is green.?
? Question: Which person is wrong?
Or how about this?
? Person 1 (Jim or Charlie, perhaps) says, ?The book tells us to do A and B.?
? Person 2 (Bob or Roger, perhaps) says, ?That does not make sense (for all these good reasons), and therefore cannot possibly be what the CMP intended.
Or how about this?
? The book says what the book says, and what the book says is "do A and B."
? If you do not like what the book says, or if you think the book cannot be followed as written, then there is a process you can follow to get the book changed.
? In the mean time, it is perhaps not appropriate to say "Person 1 is wrong," since the book has not yet been changed.
Of course, the poll was to determine the winner of the burrito, which by this time could be used as a deadly weapon...
This has been said before but I think it bears repeating. 358.30 can be paraphrased as follows:As i been saying my issue is over that one little word AND.
