CA title 24 question
Sierrasparky
USA
Electrician ,contractor
Hey I'd like to know what all you Ca EC think about Lighting changes in residential.
For example:
1) in a kitchen remodle no Sqft change. If you change the lights should it be necessary to meed title 24?
2) in a bathroom if you change out a Heat/Fan Light does it need to be title 24 complaint. Meaning put in a FL.
As I read the Title 24 workbook it seems to say if you relace it must be updated to the new code. What do most of you EC's do?
Thanks
I know you asked EC's, but I can tell you that the book says, the lighting requirements apply to alterations and additions (including replacements) as well as newly-constructed buildings.
So how how well is that inforced in Socal.
supply houses here only cary Heat/fan/ light with incand.
Well our jurisdiction is on a little bit of an island if you get my drift. We are very strict on the Title 24 and have actually won two awards from the state for our enforcement. I will admit that other jurisdictions in the area are not so strict.
I think that with the adoption of the Green Building Code that you will see that the lighting is not really such a big deal after all.
With the combo, since they are all on a seperate switch anyways, just put the light on a manual on occupancy sensor. That's how you get around the FL in the bath and other areas that they're required.
Thanks I forgot about that. I was so into using FL because of the energy savings. I usually put the Vanity on a dimmer.
Dimmers don't cut it for a bathroom vanity fixture under Title 24, they have to be either fluorescent or controlled by a manual on occupancy sensor.
For example:
Thanks
To be clear are we talking about the current T-24 or the NEW one about to come in? I have not read the new one yet... The current one is pretty easy... In the Kit just do whatever you want as long as you can keep the 50% High Efficancey... Even if it means putting in a few T-5 HO's above the upper cabs that will either never get used, or become the main lighting.... Bath heat/fan if you wanna keep that use a wattstopper power pack for all the bath lighting in a cab somewhere and an ultrasonic sensor... Also a "momentary on" switch to as a "master" for the room. (If you meastros the line load 'local switch' they will come on/fade in at the last preset level... ;) Also great for exterior for a more desirable fade in effect than flashing on 500w of floods...)
The ultrasonic UT-300 can stay on if the fan moves air, or if a cat yawns in the next room.... Run the shower or breath.... :grin:
Do all the lights have to be on the occupancy switch in the bathroom if incandescent?
Or can you have a task light?
This is a old bathroom where they want the Heat/fan vent replaced with a new unit. The old one is pretty crusty!
Straight from the book: Lighting in bathrooms, garages, laundry rooms and/or utility rooms must be high efficacy, or must be controlled by a manual-on occupant sensor. A bathroom is a room containing a shower, tub, toilet or a sink that is used for personal hygiene.
Now that being said. Are you pulling a permit just to replace a fixture?
No permit, no Title 24.:smile:
Funny you should say no permit no T24.
Bathroom remodel. Don't know if there will be a permit. Here they do all in one permits. It looks pretty bad on the GC if they move plumbing and I just pull a Electrical permit. Other than repairs a permit is needed in this city.
