mstrlucky74
- NJ
In the heading it says EMT.You have to use both parts. Both plug and receiver (?) are a matched taper... and the receiver is knurled to grip the cable.
BTW, the product picture is only listed for use with RMC/IMC.
:slaphead: You are correct.In the heading it says EMT.
I should read all of the information before making such statements. I saw the section label on the left edge of the page and read the first feature, and drew an errant conclusion. The header and second to last feature confirm the product can be used with EMT. Sorry about that.
Read the instructions on page 245.
The plug has to be squeezed closed by downward pressure. That requires the matching taper of the body.Back to this for a minute guys. So the body and plug are always used together? There's no instance where the plug only would be used?
The plug must be used in conjunction with the body.Back to this for a minute guys. So the body and plug are always used together? There's no instance where the plug only would be used?
