cloudfire181
- rapid city, South Dakota, usa
Hi was wondering if someone could point me toward a link or help solve this problem i'm having in finding total current being used across the 3 phases. So here is the problem I'm using 4 heater sets, each heater set has 2 heater in parallel with 208 Volts running across and the watts per heater set is 2000 Watts or 1000 Watts per heater. The amps I calculated per heater was 4.81 Amps or 9.62 Amps for the set I rounded up to 10 Amps, with 2 heater sets on AB, 1 on BC, and 1 AC. Now I working with a 30 Amp 3 pole breaker I was wondering if it would trip the breaker because there was 30 amps on phase A, Phase B, and 20 Amps on Phase C. Or I'm I wrong in thinking that there is 30 amps on A and B and 20 on C. Any help on this would be great.
