kda3310
- Dry Prong, Louisiana
I have a camper trailer hook up to install. 240 volt single phase. It has four breaker spaces in it. One double pole 50 amp, one single pole 30 amp and one single pole 20 amp breaker. It has matching size outlets on it. 240 volt 50 amp plug, 120 volt 30amp plug and one 15 amp GFCI outlet on it. It can not pull more than 80 amp on a single leg. I am sizing the conductor size by 80 amps x 1.25 = 100 amp. It looks likes I need two #3 THHN hots, one #6 THHN neutral and one number #8 THHN ground. I know not all things will by running at the same time. Is there some way I can run a smaller wire size and how by code?
