FionaZuppa
- AZ
- Part Time Electrician (semi retired, old) - EE retired.
sorry, could not edit in under teh 15min allowed
but if the argument is around shared gnd between DC chassis and AC egc, i would also place caution there too, all depends on if the DC gear (not power supply) has DC neg tied to chassis. many times DC gear/circuitry uses chassis to reduce wiring. if i sink amps via my mosfet i dont need to bring a wire from fet back to dc neg term, i tie the fet source terminal right to the chassis because my DC power has neg tied to chassis, this the chassis itself becomes a big CCC, etc.
AC egc and DC gnd tied into earth is not the same as DC neg tied to AC egc.
both connected into the earth is like throwing a dart blindly into a potentiometer, both land on same "device" but at different potentials. the earth is not zero charge everywhere, etc.
don, the question is, can AC and DC share the same ground? what exactly is the AC ground? its the egc. on the DC side what is the ground, its the neg terminal. so if they share same ground "plane" then you have essentially tied DC gnd to AC egc. i think that is a bad idea. i would build in isolation. the only "shared" ground would be earth.I would not expect to see either the positive or negative side of the power supply to be connected internally to the AC EGC. The grounding of the DC system would occur on the load side of the power supply output.
Remember, at SOME POINT, the "ground" connection will have to be the same... earth.
