This is portable 'temporary' applications. Can't start disassembling and troubleshooting some party rental company's appliances. I just need a tester to plug inline between the GFCI and appliance with a display I can point to that says BAD on it.You can disconnect the electronics or disconnect the heating element and only meg the components you are comfortable testing in this way. The element that doesn't fault until it is hot still may fail when subjected to the higher test voltage of a megger.
