electrickangaroo
- st.petersburg fl
have an 8 space panel that came without a bond bar. can I tap the neutral bar and install a grounding screw to bond the Can and still be legit??? not finding an answer in the nec.
Are you talking about drilling a hole through the neutral bar, thne drilling a smaller hole into the enclosure, and finally tapping threads for a 'bonding screw" into the enclosure?
exactly. that was what I was planning unless I can find some reason I cannot get away with it
well its a temporary pole. it has a GFCI receptacle and nothing more. figure if I tap the back of the box I can get maybe 4? I've tapped boxes before to add ground bars so it should set in nice and tight
I am not real sure what it is you are trying to do but it does not sound like an unreasonable solution as long as you are not drilling or tapping the neutral bar.
there is nothing that says the bonding has to be a screw. It can be a wire.
I concur......
It does not sound like it is listed 'service equipment' and if you have to bond the neutral it likely needs to be service equipment.
