TwinCitySparky
- Minnesota
Or a TV set with an ATSC tuner.
Umm, good point.
Shows how fat my wallet is.
I don't understand all of this hype about the big switch? Won't this only affect people that don't subscribe to any cable or satellite? I would imagine that most people in this day and age have some sort of cable or satellite that they subscribe to and they won't be affected.I have a rabbit ears guy that is looking for an antenna for reception of digital signals come February. Any recommendations?
Thank you.
The problem is not the number of stations, or antennas, or converters, but the broadcast power. They don't seem have any power.
And satellite providers aren't even allowed to provide stations that are available now, in analog over the air, since they are out of your "viewing area"![]()
hbiss;977851 I would imagine that most people in this day and age have some sort of cable or satellite that they subscribe to.[/I said:We would think so but that is not always true. Old people are one group that refuses to have cable or satellite. Then there are those who may have one sat receiver or cable box with other, less important sets still connected to an antenna. So they are out there.
-Hal
The Des Moines stations that are analog VHF will go back to their VHF channels for digital after the switch. We're glad to...no more water-cooled tubes, no more 30kv beam power supplies, and we'll be saving thousands of $$ each month on our power bill....As far as the channel frequencies go, I've heard that some stations will return to vhf after the switch. It is much cheaper for the stations to do this, as it does not take as much wattage to transmit the the same distance on the lower frequencies.
Thanks Garth. If we lose it was still a special season!Also congrats to your Dolphins Chris. I hope they beat Baltimore.
My first response would be that because of signal propagation, less power is required to transmit a VHF signal the same distance than a UHF signal.Grich, egnlsn, if you dig down in rabbitears.org it looks like when they do they will be greatly reducing their power.
-Hal
The DTV transition of 2/17/2009 affects OTA only. Analog will be around on cable for some time to come. Eventually, most analog will disappear from cable (they will probably keep a dozen or two analog channels), but that will be to free up bandwidth for more HD services, High Speed Internet, etc. It has nothing to do with 2/17/2009.Yes. but... not everyone installs a cable box at every tv location, but they soon will.And of course be charged accordingly. Not going to be fun for people with 10 TV's and 1 set top box for the one HD tv in the house.
If you then scroll down (within FCC Query) to the top digital listing and click "Application Info," you will see that the expiration date of that particular license is 2/17/2009 (at least for the ones I looked at). I would expect that beginning 2/17 and for the next little while, stations will be playing around with their power to optimize their coverage.My first response would be that because of signal propagation, less power is required to transmit a VHF signal the same distance than a UHF signal.
Looks like they are lowering the power from their old NTSC analog days when they move their digital signal to the old VHF transmitter.
Drill down: name>station>technical data & Screencaps>FCC query
-Hal
From an engineer at a Fox station: "Analog power is based on peak power, digital power is based on average power as well as signal to noise ratio differences of it takes to decode the analog and digital signals. You are comparing apples to oranges. It more than just power levels."The Des Moines stations that are analog VHF will go back to their VHF channels for digital after the switch.
Isn't that in keeping with only allowing low power stations to remain in the VHF band?
-Hal
For those who have procrastinated in getting their Gov't coupons, here is some bad news:
"... U.S. consumers who wait too long to request government coupons to subsidize converter boxes for the digital television transition in February may come up empty-handed, a regulator has warned...."
Full story here.
