kacper
- Islamorada
Right back at you.
I had to look up your location, I had never heard of it, looks real nice.![]()
Thank you
It's nice, good fishing and wonderful weather. The down side: extremely high cost of living
Right back at you.
I understand the fight because our firedepartment says it is not allowed but I read the code and it says it can be used in other structures(hotels) as long as the elevator shafts are in a raceway etc. I was just wanting a little clarification on my interpretation of the code. Thanks
Whatever the FD wants, the FD gets.:grin:
Understood, I do see how that happens. Behind the scenes however per the building code an M (mercantile) occupancy such as a grocery store when built as a Type VB construction is limited to 1 story and 9,000 square feet. As soon as you exceed the height or area you either have to change the construction type or use sprinklers and fire separation distances to increase the area of the structure.
It does not take much to drop a construction type and just because it has metal trusses for the roof does not automatically make it other than a type V construction. There are a lot of other factors that are involved.
Most Walmarts, Targets, Grocery Stores, Walgreens, CVS, etc are Type IIIB but we rarely see NM cable ever spec'd out because they are open truss design or lots of dropped ceilings. Many are mass walls with masonry block making NM even harder to install.
I am do not disagree with your interpretation, just explaining the construction types situation from another perspective. A recent Turkey Hill Mini-Mart was VB construction, 5,000 square feet and not one piece of NM was spec'd out by the electrical engineer.
but also standard THNN are not listed for wet location and the industry shall use appropriated conductors for such use. Appropriate insulation was the issue.![]()
