hbiss
EC, Westchester, New York NEC: 2014
- Hawthorne, New York NEC: 2014
- EC
Here is an excerpt from the article " “It's very unfortunate that copper clad aluminum products are being marketed as compliant to North America codes and standards for low voltage communications when in fact, they are not. This is particularly concerning if the cable is being used to support power-over-Ethernet devices. These cables should not be called category cable because they do not meet the standards” that require solid copper conductors for multi-conductor communications cables, including the National Electrical Code, UL 444, CSA 22.2, TIA 568C.2, and ISO/IEC 11801 ed 2.2"
That all started with the Chinese dumping that garbage on us and us buying it because it was so cheap. Most IT and DIYs have no idea what CCA is and no idea that's what they are buying. They only look at how much money they are saving.
I wouldn't use CCA for ANYTHING.
-Hal
