I have never seen that with the hundreds of fans I have installed; they pass through the center of the motor and terminate in the switch compartment where the light kit mounts.
I think adamjamma is referring to the canopy.
I hang my head in shame.
Welcome to the forum!
To me, no, the rod is not a raceway; it's part of the fan assembly. I have done this on occasion, using small wirenuts (the closer to the right size for the wire, the better the grip.)
I also stagger the joints by an inch or so, and tape them, first individually, then the entire splice length, so the tape on the individual joints doesn't unravel as the adhesive dries out.
Now, to open a new can of worms. Would it be permissible to run 18ga TFFN fixture wire down the down rod instead of full size conductors sized for the branch circuit?
I guess what it amounts to is- is the down rod part of the fixture and are you extending the fixture wiring or are you bringing the branch circuit wiring down to the fixture? Consider a shorter down rod where the included small gauge fixture wire is of sufficient length.
-Hal
Here, we're talking about extending fixture wires; no transition is occurring in the rod.Fixture wire is permitted to be used as a tap conductor to connect a luminaire(s) to the branch-circuit conductors. The transition from the branch-circuit wiring method to the fixture wire tap conductors can be accomplished via a junction box or other fitting that is allowed to contain splices.
...In fact, I usually use original fan wires from previous fan installations.
And mineHmmmm....I wonder if the back of your truck and/or your back yard look the same as mine.
I don't agree.
A down rod is made to hold the fan up.
