celtic said:A helper and I mounted 3 CFs in 45 minutes flat using the pre-assembled method
That was a great "flat rate" money maker![]()
Dennis Alwon said:Are you sure that's not "3 helpers and I mounted 1 fan in 45 minutes....":grin:
celtic said:Positive
"The Act" went like this:
Helper opened and began assembeling fans in the room locations
I dropped the 3 existing fixtures
Helper was done w/CF#1 assembly as I was done with last existing fixture.
As I finished CF#1, helper completed CF#2 assembly
As I finished CF#2, helper completed CF#3 assembly
As I finished CF#3, helper was done cleaning up locations 1 & 2.
While I settled up with HO, helper cleaned up location #3.
I "policed" all 3 locations...helper brought out all tools, materials, debris.
Done.
stickboy1375 said:Who installed the ceiling fan boxes? Because I have never been that LUCKY!!!
iwire said:Who says you need them?![]()
stickboy1375 said:bob, just about every fan I was sent to install never had structural framing above or a fan box... especially 3 in a row...
iwire said:All it has to be is independently supported from the box.
There is no requirement for structural framing.
That's not difficult. Just have the conversation before you price the job, remove the switch plate to look, and charge for the extra work.stickboy1375 said:I was just saying Celtic's one lucky guy, heres what happens when I go to install 3 ceiling fans, " So do you mind using the pull chain?" Lady replies, "absolutely not I want switches"
Oh and did I mention every room has switched receptacles?
LarryFine said:That's not difficult. Just have the conversation before you price the job, remove the switch plate to look, and charge for the extra work.
If the hot was fed to the switch, just move the receptacle's leg over; if fed at the receptacle, open that box and rewire so the loop is now a feed.
In either case, I always run a 3-conductor cable to the fan box whether I install one switch, two switches, or a fan/light controller.
No, but if I can use the existing box and wiring, and have even one experienced helper with me, I can indeed install three fans that fast, and without attaching the blades to the motor first.stickboy1375 said:I know Larry... :roll: but your not going to do it in 45 mins like Celtic got to...
electricman2 said:It's not the blade screws that give me a fit. It's the little suckers that fasten the canopy to the bracket. Try to get them in with a medalion that fits close to the canopy.![]()
LarryFine said:My only hesitation with Celtic's claim is that (a) the fixture boxes already were fan boxes, (b) the boxes had framing above them and he used lag screws, or (c) he (gasp!) didn't use fan boxes.
N
and leave one fan blade off till last for clearanceceltic said:Am I the only one that assemblies the ENTIRE fan on the ground? (Typical resi. CF type)
This was a great money maker as I said....LarryFine said:My only hesitation with Celtic's claim is that (a) the fixture boxes already were fan boxes, (b) the boxes had framing above them and he used lag screws, or (c) he (gasp!) didn't use fan boxes.
That's an extra.sparky_magoo said:My shop always installs fan boxes in locations where a HO might want a fan some day. I'm sure many of you do the same.
