LarryFine said:That's not difficult. Just have the conversation before you price the job, remove the switch plate to look, and charge for the extra work.
If the hot was fed to the switch, just move the receptacle's leg over; if fed at the receptacle, open that box and rewire so the loop is now a feed.
In either case, I always run a 3-conductor cable to the fan box whether I install one switch, two switches, or a fan/light controller.
3 wire is no longer necessary...they now make in-wall remote kits...no batteries needed and simply replace the existing switch. Let's you control the fan and the light...much quicker than running a new wire..
