weressl
Esteemed Member
UL hasn't always been perfect, no NRTL has been, they can and do make mistakes.
I reiterate, and am I the ONLY one here with any common sense, that ANY product that fails while releasing smoke/fumes as a NORMAL FAILURE MODE is a SAFE PRODUCT?! No way.
Sheesh people, get with reality. Of course, a lot of electrical items may release smoke during an ABNORMAL failure, but not too many do so as a NORMAL failure mode.
And before someone points out that motors can fail by smoking, remember what we're talking about here: an item, in the hands of ordinary consumers, in their living spaces, not a motor in an industrial/commercial setting under at least some form of supervision.
I have to say that in a forum of such high-calibre professionals, I am dismayed to read the opinions of some who think that cfl's going up in smoke at end-of-life is "acceptable."
It would NOT be that difficult or expensive to add a fuse or thermal device to prevent the smoking at end of life.
There are many things in life that I find unacceptable. I either can live with it or complain about it. Life is not going to change. There are many man-made construct that I find objectionable, but I learned to cope with it. Other routes are the way to insanity.
I agree that the 'may release small amount of smoke' is an objectionable notion. However UL - and not only UL because CFL's all around the world are operating the same way - that it does NOT represent a hazard. Until it does you are not going to force the industry to anything about it.
Have you ever seen an MV expulsion fuse go off, not on an overload, but on a major fault?
Have you ever seen an arc-lamp bulb's external glass fail while operating?
How long did we drive around without seatbelts? After that how long did we drive around without air bags. How many fatalities were there then and how many are there now per driven speed/miles? How many house fires can you document due to CFL failures? How many fatalities?
It is called perspective.
Have you heard of the "Serenity Prayer"? Here iot goes:
God grant me the serenity to accept the things I cannot change;
courage to change the things I can; and wisdom to know the difference.
