- New Jersey
- Journeyman Electrician (retired)
The issue with chandeliers is that they almost always have exposed lamps that's why I said "integral enclosed LED's", this eliminates the possibility of the lamps getting wet and also eliminates the need to replace the lamps. But you are correct there are other lighting types that do have replaceable lamps which don't seem to be a problem.But the fact you may have to change the bulb(s) I don't believe is part of why the rules are like they are. You have always been permitted certain other luminaire types that also will require lamp changes in that zone, Like I mentioned before recessed lighting in a low clearance application is and has not been prohibited, yet lamps still needed changed on those, plus GFCI is not even required.
