mshields
- Boston, MA
If I were to do a voltage drop calculation I would use Table 8 and plug in the resistance values listed under the column for Copper/Coated/ ohm/kFT. Do you agree that this is the correct source? Or should I be using Table 9?
Assuming I've been using the right table all these years, I believe that voltage drop is a function of resistance only and has nothing to do with reactance. Is that true.
Anyway, what would one use Table 9 for?
Thanks,
Mike
Thanks,
Mike
