Re: Chester the Cheetah
Hello, my name is David Clare with Cheetah USA. I was introduced to this forum by an electrician and a building inspector who suggested I jump in and just offer our explanation of many of the concerns being raised. Please know that we appreciated the honest and candid feedback. We have field tested this product for over 2 years and have received more ?honest? feedback than you can imagine
Electricians can be brutal in telling you what they think?thus we have listened and feel very good in what has been the result of some very intense field testing and feedback. I hope this will help and not distract from the forum. As you will tell from the below, we really are not trying to sell you or hide anything?so again I hope this helps?
To start with, please be sure you are hitting our right web site? our official company web site is
www.cheetahbox.com and
www.cheetahspeed.com. The site some of you have accessed is a distributor web site and we cannot control sometimes how they represent our products. Most of this information I share with you below is on our web site.
UL Concerns?
All of our products have been tested and certified to the UL specification. We elected to use two Nationally Recognized Testing Labs (NTRLs) (UL Lab and Intertek Lab) to help us ensure all of our receptacles, switches, boxes, wallplates, etc. pass the UL specifications (I understand there are 70+ pages just for receptacles and 90+ pages for switches) ? thus some of our devices (dimmers, gfci) have UL listings and others (receptacles, switches, wallplates, boxes) have the ETL listings. Both Labs are required to ensure all products pass and exceed the UL specification and standard.
For detailed information our various certification and listings, please visit our web site at
www.cheetahspeed.com and select ?electrician? and then select the left navigation ?UL & ETL??. We are still updating this with our ATM (Authorization to Mark) documents, and will continue to make this a one stop resource for you.
No ground screw on switches?
There has been some discussion on the fact that we do not have a ground screw on our switches. Again we rely upon our UL certification testing labs for passing the specification on this, and here is just some explanation.
1. Cheetah Speed Switches contain no metal straps or electrical conductive materials for electrical shock. NO Ground is necessary with Cheetah Speed Switches due to the dielectric plastic safety strap which is non-flammable, non-conductive, and non-metallic.
2. Cheetah Speed Switches (with the safety strap) can not receive standard screw faceplates. Thus eliminating any way to fasten metal or conductive screw-based Wall Plates to Cheetah Speed Devices. ONLY Cheetah non-metal screw-less wall plates can be fastened to Cheetah Speed switches.
I believe where the ?assembly? discussion comes from is that our system really is an ?integral system? or an assembly approach. While our boxes can be ?backwards compatible? to support screw devices (you insert a speed anchor and it turns our box into a normal screw box), our switches with the patented safety strap is designed to only receive our non-metallic snap and lock wall plates? For receptacles we obviously have a ground screw, but for our switches, because there is no metal involved, no conducting materials and means to fasten a metal wall plate, the Intertek electrical engineers and lab determined there was no need for a ground screw for our switches according to the UL specification. When you get a sample or handle our product you will see that the Cheetah Speed Switches, Wall Plates, and Speed Boxes work as an integral system or assembly. You will also see the quality of our boxes, our devices, and wall plates. We manufacture in China (as do all the others
). We are finding great response from those that use it?especially when they trim out. We have really tried not to exaggerate on the speed. Every electrician is different and uses different techniques, but I have personally seen many electricians wire and push in switches in 5-6 seconds and receptacles (with the grounding wire) in about 8-10 seconds. They used a drill, not a screw driver for the side mounts.
We have been very open with this approach and presented to many building inspectors and electricians. Once they see the product and actually use it, we have had wide acceptance to our innovative approach. Many recognize that the NEC code was written to obviously support the ?normal? metal strapped screw devices, but when they see our screw-less system with no metal straps and that it actually is an integral system or assembly approach, they are great with it and recognize that the current NEC code was based primarily on the current metal strap devices.
Above all we respect and support whatever the building inspectors and electricians feel comfortable in supporting. We are not trying to ram this down anyone?s throat or try to side step any issues with the UL specification or NEC code. We have taken our time to test and refine this product line to be legitimate and proven through years of testing and actual use. The power and performance is self evident and we are so confident in our results thus far we are offering a free cheetah challenge kit. This allows everyone on this forum to get the product for themselves, try it out, beat it up, and give us the feedback so we can make it better?That is what we have been doing for 2 years and are not afraid of always making things better? especially from those that actually know what they are talking about?. So please accept our invitation to give us a call, 801-973-4228? we will send you a free cheetah challenge kit with all the literature, product samples, and boxes to try it out. We would love to hear from you?
Again, I hope this has been helpful and not a distraction from this forum?.
