Patricia, I'm glad you didn't get hurt bad.Originally posted by lady sparks lover:
You know I had an application which the electrician supplied a circuit with two different breakers, and I got a nice little shock. I know that't not the same thing, but other than not being able to connect it to an adjacent load on the same circuit, what's the purpose of this?
I got over the shock, by the way.![]()
Allen, why not do what Larry said or simply put both wires on one breaker (if it's identified for two) and save the wire nut?Originally posted by allenwayne:
short of tearing the entire place to pieces there is one other thing you could have done and that is to joint them in a panel and make one termination.Does that make them parralleled I don`t think so unless they end up at same place![]()
