Sure, you can use many of them on live lines. You'd fry your fox and hound. Plus, the Amprobe kits have inductive couplers available, in which you can snap an "amp clamp" type of thing around either a conductor or a pipe and induce a signal on it rather than hooking up alligator clips.Originally posted by sparky_magoo:
Are these testers any better than the old-school toner and bananna.
Originally posted by badjeepr:
i just purchased greenlees 2011 circuit tracer and was severly disappointed! it claims to be able to effectively trace romex behind sheetrock as well as metallic conduit,pvc, check shorts opens and live circuits up to 600 volts. ill be returning it first thing tmw morning and searching for something better![]()
Originally posted by georgestolz:
What went wrong with the one you had?
It's spendy, but our shop just bought the TASCO CMT24S circuit mapper. I've used it several times and it is one nice tool. You clamp on the induction clamps at the panel over the wires on 24 circuits, it does have capability for expansion to 42, and walk around with the unit and plug it into outlets or touch the wires with it. It then tells you on the LCD readout what circuit number it is.Originally posted by badjeepr:
thank you for your suggestion george but im looking for something i can identify every circuit accurately in a health clinic without disrupting any power
