stuofsci02
 - Canada
Long time lurker first time poster...
I am executing a project for a mobile skidded piece of equipment that could be used in Class 1 Div 2 areas.
We are utilizing a Bebco Purge on our Control Panel.
In the field, all of our four motors are XPFC Enclosed and approved for Class 1 applications.
Coming out of the purged panel I intend to use a seal fitting like the Hubbel Killark ENY-3 with the appropriate Sealing Compound and Fiber, and then go into threaded RMC. My understanding is that once I am past the seal I can use standard RMC fittings.
Once I am close to the motor I want to switch to Liquidtight flexible conduit rated for class 1 div 2. Since I am going to a XPFC motor, do I need to seal it at the motor end with another conduit seal? If I do have to seal it there, does the seal need to go right onto the motors wiring box, or can it go where the transition from RMC to Liquidtight is made so long as it is within 18" of the motor?
Thanks for any help!
