- Wisconsin
- PE (Retired) - Power Systems
In that case go with all purple and number or stripe the wire.
Just don't make it a national standard.
I believe most of the EU and now the UK have standardized on
Brown/black/grey light blue for neutral. Green with yellow stripe for ECG
My guess is 480/277 wont go away any time soon but this voltage class will become a 'standard' voltage.
I can just picture a Gray-White single phase circuit.How about purple, pink, gray, and white? I know gray means grounded, but with the white also present . . .![]()
This goes beyond 416/240V. It deals with the vast number of already installed electrical installations. Any proposed color scheme that uses one of the existing common colors, of black, red, blue, yellow, brown or orange, would be a problem. You would never know if a single conductor was part of the new scheme or an existing one that is grandfathered in. I have seen people 'pitch a fit' when a motor starter had BOY on the line side and OBY on the load side so the motor turned in the correct direction. I have seen locations that would not allow BOY colors to feed their control panel because orange and yellow were reserved for 'foreign' voltages not controlled by the panel disconnect.
The problem is that the meter tells you what is there, not what is supposed to be there.Honestly I think most would agree that any good electrician uses a meter, there is nothing in the code that says the colors cant repeat.
And the important thing no matter what a decider chooses would be to avoid the existing 480/277 colors as that would be the most likely to lead to confusion.
The most likely secnerio is a code change that will allow the international scheme in some way with labeling, plaques.
Would use purple for one if these colors. Never see that color being used. Can remember purchasing 2 rolls if every color that Scotch made from supply house. Believe 10 different colors. With white,gray & green having their own desination only leaves 7 colors available. Never seen this voltage sytem anywhere .Sounds like this service is going to become popular enough that a new color code needs to be designated.
Cyan, magenta, yellow?
Purple used to be very common for 277/480 volt services before the 80’s. Then most switched to BOY. I have heard Texas still uses YBP, don’t know for sure.Would use purple for one if these colors. Never see that color being used. Can remember purchasing 2 rolls if every color that Scotch made from supply house. Believe 10 different colors. With white,gray & green having their own desination only leaves 7 colors available. Never seen this voltage sytem anywhere .
Right I forgot Texas was a purple state I think I herd that was a thing.Purple used to be very common for 277/480 volt services before the 80’s. Then most switched to BOY. I have heard Texas still uses YBP, don’t know for sure.
Those cords always have a brown for a hot and a green/w yellow stripe for EGC thats what 43 years of some light blue neutrals withouot the sky falling? No documented problems with these cords in the US.2017 NEC said:(C) Colored Insulation. A white or gray insulation on one
conductor and insulation of a readily distinguishable color or
colors on the other conductor or conductors for cords having no
braids on the individual conductors.
For jacketed cords furnished with appliances, one conductor
having its insulation colored light blue, with the other conductors
having their insulation of a readily distinguishable color other
than white or gray.
I am surprised some of our over the pond members have not chimed in?
I use both gray and white neutrals quite often at single voltage system facilities. Pulling two neutrals in a raceway in single system application - easy to identify which one goes with which ungrounded conductor(s) when making things up.How about purple, pink, gray, and white? I know gray means grounded, but with the white also present . . .![]()
Bare conductors are not white or gray though. Bare aluminum I guess sort of turns gray on the surface over timeGray and white are reserved for grounded conductors. Colors that are reserved for grounded and grounding conductors are not permitted for use as ungrounded conductors. Except in cases where energized conductors are permitted to be bare, like pole-mounted overhead wire.
