Twoskinsoneman
- West Virginia, USA NEC: 2020
- Facility Senior Electrician
Did anyone else thing 170KΩ when they saw that??
We have no tolerance for that sort of thing.Did anyone else thing 170KΩ when they saw that??
No it doesn't but myself I hate cheap tape...Won't stick or becomes a gooey mess.
And color-coded, of course. #14 - white, #12 - yellow, etc.I use that only to wrap up my coils of romex![]()
The liquid tape I use on my coils only comes in black.TOOL_5150 said:I use that only to wrap up my coils of romex
And color-coded, of course. #14 - white, #12 - yellow, etc.![]()
__________________And color-coded, of course. #14 - white, #12 - yellow, etc.![]()
I would like to see a stringent standardization in the NEC for all voltages in the future code cycles.
I am glad they keep turning that down. Not needed and will only lead to accidents.
Hows that?
I agree with Bob. That would be a stupid rule. It would be broken all the time anyway. I dont know about you but even if we had a standardized color code, I still wouldnt believe it. I have seen red as a ground, and green as a CCC. And like always, test before you touch.
The emphasis of 110.15 is its color marking by the fact that is specifies it.
Otherwise it can be effectively marked with black tape or? Consistency is safer!
I am sure green was reserved as a EGC at the time this service was installed.
Pretty sure green is a hot here but I did not bother to check. :smile:
What?
Black, Green, Brown is not the standard marking for 208Y/120?![]()
~Matt
Of course you agree!......:roll:Now on the other hand I will stay out of further conversations regarding "stupid rules" as you say.
Blue for the grounded conductor, tells me this was a non-US installer.
