Rickmar
 - Paramus New Jersey
Mini Split GFI outlet and indoor head disconnect
This new HVAC company I just started with a couple of months ago ask me to wire up their mini splits. I have done about four jobs and passed inspection all four times. The problem is when I first started with this company, I told them that your brand new installations required a service GFI outlet by the unit and I will have to install a disconnect switch by the head inside the house. This is residential work. They told me not to do these installations. Why am I passing inspections? The nearest outlets to these condensers are at the neighbors house. Since the a/c disconnect can be locked out could be sufficient to service on the head inside.? Plus what stinks about all this is that the wire going from the condenser to the head inside is done by the HVAC techs and is under my license.
Thanks,
Rick
Thanks,
Rick
