- Wisconsin
- PE (Retired) - Power Systems
Re: combo disconnect /motor starter
Ronald,
OLR contacts are on the "right" side of the coil due to the old automotive Joint Industrial Council (JIC) standards.
This location makes it very easy to:
a) wire several coils to a single overload relay as required in reversing and multi-speed starters
b) protect the OLR contact from the effects of a short in the control circuit (except for the short jumper from the coil, the contact is always buffered by the coil)
I see no violation with the location of the OLR contact as it is not a switch as defined by the NEC. All switches are contacts but not all contacts are switches (think yellow vehicles and school buses). After a quick walk through my house I found other examples of contacts that are found in grounded conductors, a motor capactitor centrifugal switch and my toaster's control lever (the UL toaster plug is not polarized).
Ronald,
