- Windsor, CO NEC: 2017
- Service Manager
Reminder fellas and ladies! Comments are due soon!
don_resqcapt19 said:The NEC covers the requirements for safe installation, not safe use.
Don
Which conflicts with the scope, 90.2(A).That seems to conflict with 90.1(A).
don_resqcapt19 said:Bob,
Don
don_resqcapt19 said:Tallgirl,
That would belong in some other code. The NEC covers the requirements for safe installation, not safe use.
Don
iwire said:Who would this requirement be aimed at?
Homeowners?
In my opinion rules added to the NEC that stand no chance of being enforced or complied with take away from the document as a whole.
don_resqcapt19 said:Julie,
The means of disconnect is already required by the NEC. There is no way that a rule that tells someone when to operate the disconnect belongs in the NEC. Also what means would there be to enforce a rule like this? It is hard enough to get the installation rules enforced.
Don
I didn't see anything about an automatic shut off in the original post. That may have some merit, but where would you require it? Around here new construction in a flood plane is not permitted.
Don
iwire said:You thought is not without foundation.
tallgirl said:Can I take that as a compliment?
