5-1 (Entire Document) The panel should reconsider and accept the proposal.
Substantiation: The TCC changes submitted to Article 250 as a result of their research is a good clarification of this Article. However, in addition to the changes proposed by the TCC, it would be to everyone?s benefit if they returned to the task and put forth the change.
What is the definition of ?bonded?? Why is there a conscious effort to evade the term ?bonded? in the proposed future text of the NEC? It is not a dirty word, it?s merely been widely misused in prior editions. Why use the phrase ?connected to the EGC? when the term ?bonded? means the exact same thing in fewer characters? (Personally, I am a fan of the term ?luminaire? over ?lighting fixture? because it is one word that says the same as two, and when the term is well defined it is very useful to all who use or teach the NEC.)
The truly horrible aspect of this situation is that people can have a conversation and visualize two entirely different current paths, one through earth and one through an effective ground fault current path, and believe the other person is visualizing the same concept. As long as the EGC retains it?s current name, the very language we speak is inherently flawed, and this simply cannot be repaired without the panel?s action. The present terminology is an undue hardship on anyone attempting to train, whether in the classroom or in the field.
The Code is not a manual for untrained persons, but it should not actively undermine training for tradition?s sake. It is not a simple task, but it is a worthwhile one for the overall value of the Code. Anyone who currently comprehends what an EGC is and it?s intended purpose will have no problem whatsoever adapting to this change, especially with the word-of-mouth surrounding these sorts of changes. Every electrician under the sun has heard and talked enough about Concrete Encased Electrodes to want to permanently join one, after the 2005 change of 250.50. This would be a similar change, self-advertising, and profoundly improve the Code.
Please, reconsider and accept this proposal.
