kwired
Electron manager
- NE Nebraska
- EC
If gas lamps are used and the gas supply fails then you can have sudden loss of light.:happyyes:Agree, if power is not supplied then it cant be suddenly lost.
The premises might only be used in daylight, and IF used after dark would presumably be equiped with suitable oil lamps or candles for convienience.
Although oil lamps and candles can be a fire risk, they have one merit over electric lighting in that each light source is self contained and a total, sudden lighting failure simply cant happen.
With a little care, oil lamps can provide safe and reliable lighting, usually best placed out of reach, but not so high up as to make cleaning, filling, and lighting awkward.
If oil lamps are all filled and started at same time and burn at same rate they should all run out of oil about the same time, but the odds of them all failing simultaneously are not that great.
If on site generators are used for lighting - which the Amish around here seem to have no issues with having electricity from a local source, just not from the utility, then you still can have sudden loss of light if the generator or something in the electrical system fails.
