Re: common neutral branch circuits
210.3 Rating.
Branch circuits recognized by this article shall be rated in accordance with the maximum permitted ampere rating or setting of the overcurrent device. The rating for other than individual branch circuits shall be 15, 20, 30, 40, and 50 amperes. Where conductors of higher ampacity are used for any reason, the ampere rating or setting of the specified overcurrent device shall determine the circuit rating.
210.4 Multiwire Branch Circuits.
(A) General. Branch circuits recognized by this article shall be permitted as multi-wire circuits. A multi-wire branch circuit shall be permitted to be considered as multiple circuits. All conductors shall originate from the same panel board.
Please keep in mind I am making a distinction between common neutral circuits and ?multi- wire circuits? Also keep in mind at this point I am distinguishing between branch-circuits and feeder circuits.
Other than individual branch circuits shall be 15, 20, 30, 40, and 50 amperes. A common neutral circuit would not be an individual branch circuit. For the sake of argument if a common neutral circuit was recognized by article 210 (I do not yet agree that article 210, Branch circuits recognizes common neutral circuits) then the circuit determined by the ampacity, is limited by 210.3. In other words three 20 amp branch circuits fed from the same phase would be a 60 amp circuit and would not be allowed by 210.3. On the other hand three 20- amp multi-wire branch circuits according to 210.4 would be classed as a 20-amp circuit or three 20-amp circuits.
