- Massachusetts
Re: common neutral branch circuits
Websters
In the case of a two wire circuit the grounded conductor is not in between anything.
If we continue to call the grounded conductor neutral just because it goes back to the neutral bar will we also call it the GEC, MBJ, EGC, etc.
It's use changes once it leaves the panel without more than one ungrounded conductor.
The document in question is dated June 25 1999, does anyone know if this definition was adopted or is it proposed?
JMO, Bob
Now who is redefining neutral?Originally posted by bennie:
A conductor that starts out as a neutral conductor should retain the same identity from start to finish, even on a 2 wire circuit.
Websters
I take Neutral to mean in between, as between gears, between sides of a debate, or in our case between two or more electrical conductors.Main Entry: 2 neutral
Function: adjective
Etymology: Middle French, from (assumed) Medieval Latin neutralis, from Latin, of neuter gender, from neutr-, neuter
Date: 1549
1 : not engaged on either side; specifically : not aligned with a political or ideological grouping <a neutral nation>
2 : of or relating to a neutral state or power <neutral territory>
3 a : not decided or pronounced as to characteristics : INDIFFERENT b (1) : ACHROMATIC (2) : nearly achromatic c (1) : NEUTER 3 (2) : lacking stamens or pistils d : neither acid nor basic e : not electrically charged
4 : produced with the tongue in the position it has when at rest <the neutral vowels of \&-'b&v\ above>
- neu?tral?ly /-tr&-lE/ adverb
- neu?tral?ness noun
JMO, Bob
