Background: I am upgrading service on a residential canal home built on cinder block colums with all walls considered break away (i.e don't mount anything on or over the walls). The new service will replace the old on the same colum. The mounting surface is 12" inset off the vertical wall run to the roof were the mast will penetrate and rise an additional three feet to the weather head.
Problem 1: If I use 2" RMC from the Meter box to the Roof I am faced with the need for an offset exactly 12" in the run. I can find no listed fitting to make this turn. 45 degree galvanized plumbing fittings would physically do it, have the strength, and I'm sure conduct just fine. Is this allowed? If not, what is the correct way to get this bend. None of the hardward stores or electrical supply stores nearboy will bend the 10 foot lengths to custom dimensions. There has to be an easy way.
Problem 2: If I chose to put a 2" RMC mast at the roofline joined to PVC. I am still having problems locating a listed joint, making the precise 12" bend and now am also faced with how you bond the "floating" RMC at the top. I don't see any common methods or attempts at bonding this section in a few examples of other's work where... they inserted 1.5" PVC into the RMC with no fitting and did not bond the RMC at all.
This is an unusual project and would appreciate any suggestions from the group. Thanks in advance.
Additional Info: 2/0 Cu wiring, Run crosses the street so I have to go through the roof to get the required vertical height, no other good place for the meter box or exterior load center, 18" vertical from meterbox to the wall ledge (12" horizontal) then a 10' run along wall to roof line then another 3' to weather head.
Current plan: have custom 2" RMC nipples manufactured for use with two plumbing 45 degree elbows.
John King
John King
