gar
- Ann Arbor, Michigan
- EE
091215-1259 EST
Don's comments seem to be the most useful.
Going back to what I said before take the computer that will be used with the TV display and test in the store the ways you can connect the two together and evaluate the performance. Depending upon the money that is available it may mean changing computer model or other compromises.
Some basics:
VGA is an RGB (red, green, blue) analog signal, with separate horizontal and vertical sync signals. You can put out any desired pixel resolution within the capability of the VGA chipset. The internal D to A converters in the VGA determine the quantizing level for color intensity.
If the pixel rate of the source does not match that of the screen, or a sub-multiple, then there will be some sort of smearing. Thus, in the case of a 1080 screen you want a VGA vertical resolution of 1080 or 540 lines. There is nothing the display can do to solve the problem except that if the number of vertical lines is between 540 and 1080, then match the lines of the screen to the input lines. For example a resolution of 1024 x 768 could be displayed with only 71% of the vertical part of the screen used, and a one-for-one relationship. However, what my TV appears to do is to map the 768 lines into 1080.
Also there appear to be VGA resolutions that the TV won't map, screen displays unsupported.
All of this means it is important to experimentally evaluate how the PC performs with a particular TV. Also consider what Don said about the possible life of the TV, its cost, and how it may be used in the future.
Some basics:
