A costumer asked me to splice a junction box to get covered by sheatrock. Is there anything now made for this ?
If not I'm having an issue locateing the code requirement for not burying the box in the wall.
Please direct Thank you.
https://www.homedepot.com/p/Tyco-Electronics-Romex-Splice-Kit-3-Wire-1-Clam-CPGI-208169-2/202204327A costumer asked me to splice a junction box to get covered by sheatrock. Is there anything now made for this ?
Thank you, that's good to know. he texted two outlets.. ?? are they required receptacle,lighting... are they feeding through elsewhere not just in and out..
Good to know these Tyco plugs exist... wonder if they have some type of full product line instead of just in and out??
Code be damned, I would rather bury a good tight wire nut splice than use one of those tyco things....
Why?
I must be the exception.Because those Tyco or TE Connectivity splices are possibly the only thing that are hated by more electricians than arc fault breakers.
Maybe I know how to use them. :huh:I imagine the stories about seeing them only burnt up are probably because they are a pain in the ass to use and were probably never properly terminated in the first place.
As I said earlier, maybe one or two can be hidden better. Thought: what's on the other side of the wall?the homeowner can't live with a visible blank plate or two over a junction box that is accessible?
Nevertheless, they are listed and designed to be used without a box. I imagine the stories about seeing them only burnt up are probably because they are a pain in the ass to use and were probably never properly terminated in the first place.
Pretty much my thoughts. Why not install unbroken run in the area in question and make the splice accessible in a crawlspace or in a closet, utility room, etc.? In a kitchen maybe make a splice accessible inside a cabinet, behind the range or refrigerator, on top of cabinets yet out of sight. Install a larger box if necessary and splice in same box with non associated switch, receptacles, lighting boxes, etc. that are going to remain in place.Can the two cables and the box be replaced with two new boxes connected by an unbroken cable, or otherwise reroute the cable pathway?
Thak you for the replies. I'm going tomorrow to check it out. The walls are finished. He's adding book shelves or this of that. I don't know what he's doing ??? But besides concealed splice it also may be removing receptacles where required for wall space. He says the receptacles aren't required by code ???? Oh. Ok.
I'll see tomorrow. Thanks again.
