weressl
Esteemed Member
iwire said:No, here the electrical inspector must look at the re-bar to verify NEC compliance if the rebar is to be used for an NEC application.
Besides, I am not sure the local building department would allow rebar to poke out of the footing. That is a place for corrosion to start breaking down the footing.
Oh, so whatever else is the "bonding" condutor - that ALSO pokes out of the footing - is corrosion proof? Especially if it is a different material. A Cu/Fe battery.....
