dan55
- South Dakota
Need a 3 1/2 hole to set a pan box into Concrete siding. Any body found anything that works good for this purpose. (other than destroying a hole saw bit) . Does somebody make a hole saw for concrete siding?
Oh yes I nearly forgot that one - that does work well - really well! The carbide does burn up though... And I think they too have gotten into diamonds...I would use a Roto-zip with the carbide tile bits.
another work around is to cut a rectangle using die grinder, then using alzac, make a lighting block, which you can cut a hole into for light box. caulk around alzac.
We've have many builders do this, or use cedar, or other materials.
We've had some use a router and give it curved edges.
We've even had some outline the lighting fixture so the alzac was shaped like the light.
The carbide grit hole saws work very well with the Hardy Plank ( concrete) siding. I cut the hole in the siding first exposing the OSB or plywood underneath then change to a regular hole saw to cut hole out. It seems the grit hole saw do not do as well in wood and create a lot of heat.
Ty,
Do you me Azek trim? If so, and alternate will be Miratec.
c2500
You mean the grit ones right?A carbide hole-saw drilling tip: they cut both equally well turning clockwise or counter-clockwise.![]()
Yeah. I must have had a![]()
