K8MHZ
- Electrician
Use a wago.
That may have been the brand/product at the supply house that actually had a wire range starting with a single wire on the box.
Use a wago.
I guess one maybe needs to define what primary and secondary cover means, in the OP there is still one more cover to remove before you can get a screwdriver on the breaker lugs.
The secondary cover was already removed in the pics shown.
Might just have to take off the remaining dead front to get to it eh? If that isn't enough room unplug the breaker from the bus and then you should be able to get the crimper on there.I just took a look at the 3M clear capped crimp on end connectors and they are listed for a single wire.....getting a crimper in the OP's spot might be tough, though.
..... idc about wirenuts being rated for more than one conductor.
regular wirenuts screwed onto the insulation. (Sorry Chris)
