petersonra
- Northern illinois
- Semi-retired engineer
DaveTap said:Code allows conduit as ECG, but I'd tighten the nuts and add ground-bushings and wire at each end especially if you're going to be using AFCI or GFCI from that panel. (a ground fault will have to travel all the way to the main panel to sense) I figure if NEC doesn't allow just the electrical nuts at the service why would I allow it for a sub panel? That being said I find conduit to be pretty reliable ECG as long as all the fittings and nuts are tight.
I don't see how AFCI or GFCI has anything to do with it. They will trip far more reliably on a GF condition than will a normal circuit breaker that relies on a high level of current to trip.
