Re: conduit bonding
Physis,
I think you're describing an antenna.
No, I'm describing basic right-hand rule generator physics (or left-hand, depending on one's definition of what moves as current).
When a conductor moves through a magnetic field, breaking lines of force, current is created in the conductor.
The motion of field and conductor is relative. If the conductor is stationary, and the field moves, the effect is the same. Current flowing in a conductor creates a circular magnetic field about the conductor. To this magnetic field, the conduit wall will appear as a solid block of metal in between the poles of a magnet, but, because the field is circular, there is no beginning (North) or end (South), only direction. When the current in the conductor increases, the magnetic field density it creates also increases. As the field passing through the conductive conduit metal changes density, eddy currents are generated.
The eddy currents created in the conductive conduit circulate in the conduit, circulate in complete circuits never leaving the conductive conduit.
The faster the rate of change of magnetic field density, the greater the eddy currents.
Dereck is referencing research stating the eddy current induced back EMF in the conductor in the conduit is smaller at 60 HZ fault current rates of change than had been previously understood, at least by me.
