- Massachusetts
So I can work off a ladder of virtually unlimited height, (would hate to carry that one around) not have to attach myself to either the ladder or something else
That is my understanding.
How would you tie off from the ground before climbing the ladder?
but if on a scaffold 5 feet off the ground I must have a railing and possibly need to attach myself to something should I slip and fall?
Scaffolds are also different rules, at 10' you need compliant railings.
1910.28(d)(7)
Guardrails not less than 2 x 4 inches or the equivalent and not less than 36 inches or more than 42 inches high, with a mid-rail, when required, of 1- x 4-inch lumber or equivalent, and toeboards, shall be installed at all open sides on all scaffolds more than 10 feet above the ground or floor. Toeboards shall be a minimum of 4 inches in height. Wire mesh shall be installed in accordance with paragraph (a)(17) of this section
