A long time customer is having a new 2 car garage put up. I was not available when the footing and floor were being poured and the company doing the work said that they knew exactly what to do and would take care of it. I figured they would turn up a piece of rebar out of the floor into where the wall would be They left us with this:
I know that I can extend it using irreversible means, but I am curious about something else. I believe it would be code compliant to connect that CEE directly to the ground rod which I will be installing there anyway. I would have to use a #4 to connect the ground rod to the panel instead of the normal #6, though. Do you agree that is compliant?
Second question, I am looking for an inexpensive crimper to use to extend #4 copper. I do resi service and have no other need for a crimper. I just want to use C-crimps on (2) #4 copper cables. I need to find the crimps and proper crimper. I don't need something big and expensive like the Burndy MD6.
I have done a lot of searching here and other places and see people talking about this, but when trying to find the actual crimper and a supply of the proper crimps I come up short- the same with talking to the supply house guys. Does anyone know of an online source for a crimper like this and the proper crimps?
