Open Neutral
- Inside the Beltway
- Engineer
A friend in the Sandy Eggo area just had a well drilled. Gulp, 1500 ft.
The well driller wants to sell him a:
GOULDS 7GS30 7GPM 3HP 4IN PUMP END
CENTRIPRO 3HP 230V 3PH 4" SUB MOTOR
3HP AQUAVAR SOLO CONTROLLER 1PH IN/3PHASE OUT CONSTANT PRESSURE DRIVE
and 880 ft of
1.25IN DEEP SET PVC DROP PIPE W/SS COUPLING,
to fill a 5000 gal tank @ 7 gpm.
I'm trying to understand what makes this Goulds-3AS30 Aquavar SOLO VFD so fancy, and expensive. Given the well dumps into a tank, there should be zero head pressure at the tank, so why does he need or want a "constant pressure" VFD? How will the output pressure vary, and why would it help to adjust the motor speed in a start-stop tank fill application?
I calculate:
380psi at the pump [0.432psi/ft * 880 ft]
the dynamic head @ 7GPM - [0.2psi/100ft * 9 hundred ft = 1.8psi]
So why does he need or want a "constant pressure" VFD? How will the pressure vary, and why would it help to adjust the motor speed in a start-stop tank fill application?
Other things disturb me, too.
380 psi is near the [normal] Schedule 80 pressure rating per one source [470 psi@73F - http://www.harvel.com/technical-support-center/product-specifications/pvc-pipe-schedule-80];
they will hang the pump from the PVC, not a stainless wirerope, etc.
What keeps the pump from torque twisting on startup?
But that's all for later.
Given the world class VFD gurus here, I'm sure I'll learn something on this topic....
and 880 ft of
I calculate:
