thepij
 - South Killingly, CT
 - Electrical Engineer
I have an open walled structure, concrete slab, steel columns and roof. The owner wants to reuse 400 watt metal halide high bay work light. This fixture is identified as economical, efficient and cost effictive TEMPORARY lighting fixture for construction sites. My question is can this be used for permanent lighting? The manufacturers literature does not state if it is damp location rated which I think will be needed. If it is advertised as temp lighting, then installing it as permanent would not be used per listing.
