It doesn't matter how many stickers or warnings you put on a cord reel, Unless you have an overcurrent device built into the reel itself that will disconnect the load prior to causing damage, there is nothing that will keep the customer from not ever being able to overload it.
Therefore,
The best thing you can do is stop at the receptacle outlet where the Cord Reel will plug into and let the customer supply his own if he wants to , or, if Spec'd on a project and you have to provide it, it then needs to go through the correct submittal process and approvals so that the cord reel and installation that is used takes the liability off of the installer.
JAP>
Therefore,
JAP>
