LarryFine
- Henrico County, VA
- Electrical Contractor
I believe the premise of the rule was to keep kids from pulling on the cords and causing crock pots, coffee pots, etc. off on them and scalding them.So these would not be compliant?
When the countertop company came to install the top he told the homeowner that he wouldn't recommend cutting a hole in the stone for the pop-up because it would weaken the stone and might break.
How about banning electricity if kids live in the house?So we have a bunch of smart folk here. How about we come up with a reasonable way to install outlets on the side of the island and prevent the hazard of kids snagging cords?
My thought has been to require a some sort of mechanical cord chase to guide the cords to the countertop. This could be as simple as some sort of decorative bridle rings. Maybe require semi-recessed angled receptacles so that the cords point up toward the countertop rather than out away from the countertop.
It seems to me that a real safety problem has been identified, but that solutions are possible without eliminating the benefits of island receptacles and without forcing the most expensive counter top solutions.
Yeah, in all my travels I rarely see anything plugged into Island receptacles other than phones chargers.Oddly, I've never had the need for a receptacle outlet on my island.
My mixer, air fryer, toaster, coffee pot, etc.. is plugged in on the counter.
All we use the island for is to set the food on after it's prepared.
Jap>
That's because people rarely leave something plugged in and sitting on an island. I use my island receptacle several times a week but I don't leave the toaster or vacuum sealer sitting out on the island 24/7. They remain in a cabinet until they're being used. Same thing would apply to a blender, food processor, etc.Yeah, in all my travels I rarely see anything plugged into Island receptacles other than phones chargers.
Same here. The air fryer, toaster, and slow cooker are only there during their use.That's because people rarely leave something plugged in and sitting on an island. I use my island receptacle several times a week but I don't leave the toaster or vacuum sealer sitting out on the island 24/7. They remain in a cabinet until they're being used. Same thing would apply to a blender, food processor, etc.
Depending on what code cycle you're on you could be permitted install the receptacle on the side of the island. I would bet that many people dislike the pop-up style receptacles cut into the countertop.From what I remember reading the NEC stopped allowing receptacles to be mounted on side of islands was due to young kids & even adults catching on the cord and pulling over a hot container. Now with life time liability laws I would never install such a receptacle even if customer paid me in cash. The pop up receptacles are a much safer choice.
Nothing I read disallows them on the side. They did change what receptacles are required as well as made it somewhat optional to have the required ones.From what I remember reading the NEC stopped allowing receptacles to be mounted on side of islands
So how far below the countertop on the side of the island would render the receptacle as not one of the "Receptacle outlets, if installed to serve an island or peninsular countertop or work surface"?Nothing I read disallows them on the side. They did change what receptacles are required as well as made it somewhat optional to have the required ones.
As worded if the receptacle is intended to serve the countertop it must be in or above the counter top and no longer allowed to be below the countertop.
Anything below because of the way they worded it. They have no wording that prohibits having outlets below the top of the counter, just wording that says if the outlet is intended to serve the countertop space it must be in/on or above.So how far below the countertop on the side of the island would render the receptacle as not one of the "Receptacle outlets, if installed to serve an island or peninsular countertop or work surface"?
So 6" below the countertop and I just tell the inspector they didn't want any receptacles to serve the island countertop? I mentioned this a few months ago in another thread where the wording should say any receptacle below a given distance from the island countertop is NOT serving the countertop. The old code versions used 12" so it should give an explicit measurement.Anything below because of the way they worded it. They have no wording that prohibits having outlets below the top of the counter, just wording that says if the outlet is intended to serve the countertop space it must be in/on or above.
That’s total BS. Almost every countertop I’ve seen (including mine) have holes drilled in them for faucets and air switches.
I know this doesn't negate all dangers but most modern fryers and slow cookers use break away connections.
I don't think air fryers have the same safety rules as deep fryers.The only break away connection my old air fryer has would be if it fell off the counter full of French fries the weight of it might possibly jerk the cord out of receptacle,,,, but, I doubt it.
Jap>
