Covering hole in plastic box
Will Wire
California: NEC 2020
Electrical Contractor
Other than removing the box and replacing it, is there a code compliant method for covering a hole in a box when a Romax wire has been removed during a remodel and the box supplies a receptacle in another room and will be remaining. Thanks.
Once you remove the cable it does qualify as an unused opening so it is required to be closed. As rc stated I've never seen someone who cared but it's a valid question.
