tallgirl
- Great White North
- Controls Systems firmware engineer
On Saturday I was asked to hook up a hot water heater in a building that's getting ready for occupancy. They had to switch from gas to electric hot water as it seems the local gas company has not yet made the gas service, uh, usable.
I assumed that all I was going to do is connect from a 4" box to the heater. When I got there I found that, uh, I was going to be doing a bit more than that.
I found that the heater was installed as a "transverse partition cord and plug attached device". Meaning, someone drilled a hole through wall and plugged this 2kVA heater into a 15A outlet using a sliced up extension cord.
After much arguing, which included words like "death", "electrocution" and "fire", I explained that I couldn't just turn the outlet around and plug the heater in without having the "partition penetration feature" ("hole drilled through wall") no longer being used. Oh, I also said things like "Sure, you can find someone who'll do it, but they won't be a licensed electrician." I then explained the finer points of "can" and "may" and their role in the English language.
We then set about finding someone who was appropriately experienced, not busy on a Saturday, and willing to work for free. I was given a Giant List of Stuff to buy, some of which I knew what to do with.
After running all the Brand New Wires and playing Juggle The Circuit Breakers, this is what we wound up with --
