OP may like to do it.Every household kitchen needs a megohmeter in the cupboards![]()
It is the nature of married couples to disagree. My evidence is anecdotal based on personal observations of others and my own life experience, but I haven't come across an exception yet.I have a habit of unplugging unused appliances and my wife thinks it is unwarranted.
(understood it needs to be plugged in when being used)
I have witnessed shorted appliance cords a number of times. Usually a 20 amp circuit so it can make a mess.
Quote of the year hereIt is the nature of married couples to disagree.
Its likely during the remodel you will end up with AFCI protection, if any recpts are replaced.
On my kitchen counter, the recp I plug toaster into and unplug is now quite loose. It was probably a .39 cent special I got from Eagle Hardware, before they become Lowes. If I replace it I have to use a AFCI...or probably the DF type with GFCI.
I am concerned about this. The panel was replaced right after we bought the house, about 12 years ago. I do not know whether it is a type that can accept AFCI breakers. In one sense, the receptacles are not being replaced, in that they are essentially being relocated (from wall to under cabinet Wiremold). But the old ones won't be reused, so this is a weak argument. I will discuss with the assigned electrician, but only if he or she mentions it first. :happyyes:Its likely during the remodel you will end up with AFCI protection, if any recpts are replaced.
Your breaker panel will accept AFCI breakers I'm sure. I would never install them in my own house.I am concerned about this. The panel was replaced right after we bought the house, about 12 years ago. I do not know whether it is a type that can accept AFCI breakers. In one sense, the receptacles are not being replaced, in that they are essentially being relocated (from wall to under cabinet Wiremold). But the old ones won't be reused, so this is a weak argument. I will discuss with the assigned electrician, but only if he or she mentions it first. :happyyes:
My own opinion is that the reason why the british designed their outlets with on off switches in them is because they felt that the act of unplugging the cords would lead to the cords eventually breaking from the strain of unplugging them improperly while in a hurry. You want prove this is possible? Own IPads and have grandkids using them... see how many IPad cables you go through yearly. Now imagine it was not 5volts 2Amps but was 120volts 15amps...
If it was replaced with something "new" 12 years ago, it has AFCI's that are listed to work in it. Same product lines being made today were available then.I am concerned about this. The panel was replaced right after we bought the house, about 12 years ago. I do not know whether it is a type that can accept AFCI breakers. In one sense, the receptacles are not being replaced, in that they are essentially being relocated (from wall to under cabinet Wiremold). But the old ones won't be reused, so this is a weak argument. I will discuss with the assigned electrician, but only if he or she mentions it first. :happyyes:
I don't see how a switch effects the strain put on the cord when pulling on the cord instead of pulling on the plug itself, unless this switch also would have a mechanical "jaw release" for the receptacle.My own opinion is that the reason why the british designed their outlets with on off switches in them is because they felt that the act of unplugging the cords would lead to the cords eventually breaking from the strain of unplugging them improperly while in a hurry. You want prove this is possible? Own IPads and have grandkids using them... see how many IPad cables you go through yearly. Now imagine it was not 5volts 2Amps but was 120volts 15amps...
