busman
- Northern Virginia
- Master Electrician / Electrical Engineer
So, being a 95% residential/service guy, I'm coming to my first service with a GRC enclosed service entrance conductors (between the meter base and the service disconnect). If I understand it correctly, the GRC needs to be bonded with a supply-side bonding jumper; this is easy enough. My question is, since the GRC is connected to the meter can and the meter can is bonded to the grounded conductor, there will be current normally flowing on the GRC in parallel with the grounded conductor. I can't see that this hurts anything, but it seems odd. Do I have this correct?
As always, thanks.
Mark
As always, thanks.
Mark
