winnie
- Springfield, MA, USA
- Electric motor research
[crossman's questions in post 191]
1-7: Yes
8: No
9: Unclear
10: Yes
11: Yes
I have to recognize that I have been conflating a physicist's definition of capacitance with an EE definition of capacitor. But while a single electrode can have capacitance, it takes two electrodes to make a capacitor. The two definitions are not inconsistent; if I have two spherical electrodes separated by a large distance, I can treat that as a capacitor. Furthermore, I can take the formula for capacitance of a sphere, apply it to the two electrodes, and then apply the formula for series capacitances, to calculate the capacitance of this strange capacitor. (And this is a strange capacitor; as the electrodes separate, the capacitance goes down to a finite, non-zero value; once the distance is large enough, the capacitance does not really depend upon distance.)
I'd like to propose another circuit, in the vein of your examples and Smart$'.
In this circuit, current will clearly flow each time the switches get cycled. Current flows out of the positive and negative terminals of the battery during each switch cycle, in an essentially balanced fashion. But with one switch open, when you close the other switch, you don't see current flow on the wires leading to the other switch. The current flow in different parts of the circuit is different. As I said in a previous post, over the portion of the circuit where the electric current is not flowing, the electric field is changing, in a way that accounts for the lack of current flow.
Back to your example, I believe that you are suggesting that the open switch itself will act as a capacitor, and that the entire charge flow to the large conductive object would be balanced by charge flow right up to the switch contacts. I believe that in fact the battery itself will act as a large electrode; and that the entire battery assembly will become slightly negative as the conductive body becomes slightly positive. I believe that the electric field over the entire circuit will redistribute once you close one of the switches.
-Jon
1-7: Yes
8: No
9: Unclear
10: Yes
11: Yes
-Jon
